Any good temp repairs for rear window crack other than packing tape?
Hi Guys
I'm sure someone has a creative temp repair for a small crack I have in my rear window on my 1999 Boxster.
What are your creative ideas?
Prompted to use tape when dealer quoted me nearly $5000 for new top just because window cracked. Top in otherwise fine shape. (I suspect had I the time and place to do the work I could install new top myself at cost of my time and of course the cost of a new top. Might explore this at some point in future if I still own car and the top needs updating.)
Finally got tired of tape and rear window's aging -- car an 02 -- and decided to have rear window replaced. Had it done at local shop but not real happy with the job. I expected old window to be removed and new one sewn in its place.
Old window cut out leaving the sewn in border still in canvas. New plastic window sewn in and now top has two rows of stitching around rear window opening. New window very clear, quite flexible, and water tight, but I would have preferred to have the old window completely removed before installing new window.
If you have new window installed be sure you get in writing the installation details and your happy with them *before* you give go-ahead to have new window installed.
Sincerely,
Macster.
I just did a quick search on Google: http://www.homeandbeyond.com/prod-0000108.html
I'm sure you can get it at Home Depot, Lowe's, etc.
Good Luck!
