windscreen disconnects on highway
i'm driving down the highway and all of a sudden the wind sounds different. I look back at the windscreen and the passenger side is disconnected and i have to hold onto it so it doesn't fly off.
It seems the connection is loose on the passenger side and fine on the driver side.
Can i replace the piece that is attached to the rollbar or do i need to replace the windscreen?
It does not look like the padding on the rollbar comes off..........
Are you talking about the clear plexiglass windstop in between rollbars, or the mesh screen inside the rollbar hoops? If it's the mesh screen, just insert a couple of small black zipties to hold the screens onto the rollbars. If it is the clear plexiglass you are talking about, you can buy replacement clips to hold the windstop in place.
Mine's broke too, I'm just procrastinating fixing it. If the clip on the rollbar is bad, it's about a $5 part and attached with a rivet that you should be able to drill out once you remove the plastic cover off the rollbar.
Honestly, I've found I don't really notice the difference with it on or off, so I just leave it off.
I had the same experience but on mine it was the piece on the windscreen. 4$ later and I had replacements which just pry off the windscreen and snap into place. Are you sure its the part on the rollbars that needs changing?
