987 S Autocross Alignment
Hello- Don't be scared - I have escaped from another forum to ask for some help.
I may wind up at an autocross with my wife's bone stock 987 S and would like to put some negative camber in the front to keep from shredding the outside edges. It has the 19s with Pilot Sports. It is primarily a car to tour with so I do not want to get too radical. Anyone out there with a suggestion/comment on some alignment specs thay have been pleased with ???
Thanks in advance -
BTW -I do really like the car and may break down and get a set of 18s with some "R" compound tires later on.
Thanks in advance -
I don't think you will need to monkey with the alignment. I have a stock 02 S and do auto cross events. My times last year were competitive in my group (novice) and usually within a second of the non-novice group (PCA AX classes). Keep the air pressures right and you will not do a lot of damage to the tires. My fronts have about 18K miles, 7 or 8 auto crosses and a DE on them and they are in fine shape.
Basic Site Sponsor
Basic Site Sponsor
Sorry, I don't agree. There is virtually no negative camber on the front of my 987 and if driven hard would kill the tires at an autocross. Take one of the 3 strut bolts off to see if you have room to slide the strut top inwards. A quick and dirty way would be to move both inwards the same amount, re-set the toe, and leave it that way. It will probably not get you more than -3/4 of a degree but it would be acceptable for street driving as well.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
FYI, the box has around 8deg caster & gains a LOT of camber as steering angle increases. you can still benefit from a bit more static camber than OEM. FYI, most boxsters are aligned w/ around -0.3 deg camber up front from the factory, although the spec leaves a lot of wiggle room.
a stock 987's front camber should be adjustable from about +0.1 -> -0.8 degrees. if you mark the current location on the strut towers, you can slide the struts all the way inboard to max out neg camber. this WILL affect toe, but only slightly & in the outward direction. IMO it's not enough to matter on an auto-x course.
also even out your tire pressures so they are about the same F/R. i use 39 cold at auto-x on a box.
