Left front wheel noise
Picked up the car this morning. It was indeed the bearing. My total out of pocket was $149 because I bought an extended warranty that covered it.
Total bill was over $950. Parts were about $100 the rest was labor and a $229 alignement.
Got the car back freshly washed and they filled the tank!
Thanks again for all the info and tips.
If it just started, the question to ask yourself is when are you due for a clutch replacement? That would be the best time to put in the new updated RMS.
Personally I am going to replace my Flywheel (with a light weight one), performance clutch and pressure plate, RMS AND the IMS update from LN Engineering. I know that part is $600, but worth the piece of mind!!!
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
Hi Rob,
I know the RMS is not the end of the world, but the extended warranty ends in January. If I get the RMS done under warranty, it covers the labor for updating the clutch and flywheel (all I have to do is buy the parts).
Ray - what's the deal with the light weight flywheel? What brand? How much better is throttle response? Any issues with stalling? Did you upgrade the clutch as well?
Ironman 140.6
Throttle response is greatly improved. The biggest adjustment I had to make was to get used to the quicker drop in revs when heel and toe downshifting.
All in all it's been a great mod IMHO.
