Can the lower control arm ball joints be replaced?
I just pulled my hubs so I could replace my front wheel bearings. In the process, I accidentally ripped the boots on the "ball joints" on the control arms. I checked the parts diagram (I cropped the page with my item below), but I don't see them listed as an individual item... can they be rebuilt or replaced?
Thanks in advance.
- Mike
Thanks in advance.
- Mike
you can't replace the ball joint. the boot comes off if you use a chisel to separate the boot collar from the control arm. you can then replace the boot with a generic one. IMO, this is pretty unnecessary since the ball joint is the dry / nylon race type rather than a wet, steel lubricated piece.
boot or no boot, the thing will squeak like hell someday.
FYI, Vertex Auto has been rebuilding these control arms w/ new ball joints, but you really can't do this without special equipment.
I can replace the boot with a generic one? What do you mean?
- Mike
you can buy generic rubber boots from pep boys. just find one that looks to be about the right size. push it on & secure it with baling wire.
i use a little pb blaster to lubricate the ball joint internals. regular grease is to thick to get down into the race. the pb blaster usually keeps the squeaking to a minimum.
one more thing: when you DO finally replace the control arms, use the GT3 shimmable versions. this does two things:
1. provides for greater camber adjustment w/ shims
2. allows you to just replace the outer portion of the arm in the future if a ball joint goes south
i'm pretty sure you can use the GT3 arms in BSR, but i think they give you a choice between the GT3 arms or camber plates.
Thanks for the advice - I appreciate it!
- Mike
you should find out if you can use the GT3 arms in BSX without shims. this gains you nothing from a performance standpoint, but allows adjustment later if you change classes. also allows you to buy the cheaper ball joint option.
- Mike
Dallison28 was kind enough to send me an old control arm to mess around with. I wanted to see if the rubber could hold up to oven temps while i powder coated the metal.
It did. And then because the ball joint was messed up i decided to take it apart and see if it is replaceable.
There is a small metal clip at the top of the boot. You can easily remove this, then take a chisel and it looks like two washers holding on the boot. Just pound the chisel to break this loose and then the boot will come off. I have been looking on the TRW website to find a replacement but unable.
Now i have no idea how to get the ball joint out properly. I think you can put a nut on the threads and with the arm supported you can press the ball joint out.
The bottom of the ball joint is held in by a steel disc that is pressed in. That is all i can see that holds it in. There shouldn't be any downward movement anyway.
Oh and there is a quite a bit of grease in there.
My neighbour has a '63 corvette. (I know i tell him everyday). And he wants to paint his valve covers. This color was a test.
