tire pressure monitor
What can be done to aftermarket wheels to make the tire pressure monitor system work? Is it a problem to turn it off or does it keep giving a warning?
Ed
Ed
This is from the Wheel section from the General Section:
"Tire pressure monitoring systems (TPMS) are now impossible to run from when buying a new vehicle. Every new vehicle made for sale in the USA has a TPM system as standard equipment. There are several exceptions though: the vehicle must have only four wheels (so no dual-wheeled trucks or motorcycles), and the GVWR must be less than 10,000lbs.
Porsche has been keeping up with TPMS technology since 1986 when the PSK system was introduced on the 959. Fast forward to the 2003 Cayenne which came with a more advanced TPMS which was then carried over to the 997 Carrera, 987 Boxster, and Cayman. Porsche has used a direct valve-sensor-based system on all of their vehicles with a TPMS and we carry each valve sensor for all models up to the 2009 model year.
The basics of the direct TPMS is that it uses a sensor in the wheel/tire to wirelessly relay pressure back to the driver on some sort of display. Some vehicles have a digital info screen that will show all four tire pressures (five pressures if spare has sensor) all the time. While others might just flash a low-tire-pressure light on the dash. There are also two different styles of sensors for this system: a valve sensor and a strap/band sensor. Only valve sensors are used by the direct system-equipped Porsche’s, although if you bought an aftermarket SmarTire TPM system, those use the sensors held on by a strap around the barrel of the wheel.
Although no US-spec Porsche model has ever had an indirect TPM system, I feel the need to explain it just to clear up any confusion. Any indirect system will not affect the choice of switching aftermarket wheels or tires. The system runs off of the ABS/wheel-speed sensors which “count” the number of revolutions of each tire. If the right-front tire is low (25psi) it will spin faster than the left-front tire (35psi), so the ABS system will recognize this change and alert the driver with a flashing light near the gauge cluster and possibly a loud chime.
All Porsche valve sensors are currently being produced by BERU and are sold by us in two parts: the sensor component and the metal valve. The size of the sensor shouldn’t be a problem for many wheels, but if the valve hole is in the middle of the wheel’s barrel, then obviously the sensor will not fit properly. The wheel industries are aware of the valve sensors and are rushing to get most of their wheels TPMS-compatible. If you have any questions about the TPMS-fitment on a wheel that The Tire Rack sells, I can look up the wheel and confirm if it will work with your vehicle.
damon@tirerack.com
800-428-8355 ext. 643
**Don't forget to add my name to online orders!**
Or use this link:
http://www.tirerack.com/affiliates/l...sp?AFFCODE=AQ5 "
damon@tirerack.com
Or use this link:
