Boxster guru/dealership mechanic help needed
The car is a 2002 Boxster S. My wife and I have been experiencing some problems operating the alarm with the key fob—sometimes it arm/disarms, sometimes it doesn't. My wife will occasionally need to manually unlock the car, which can trigger the alarm. Our independent Porsche mechanic hooked it up to his diagnostic equipment and it spit out two fault codes: 54 (or 56—can't remember) and 60.
The 54 or 56 code says that something isn't locking properly or fully, and this faulted 16 times. The 60 code says the radio receiver is faulty, and this fault showed up 21 times. Does anybody know if the 54 or 56 code tells where the fault is occurring? Also, is the radio receiver the same thing as a control module for the security system, or for all the electronics in the car? My mechanic's system can read the code basics, but he doesn't have the full-blown dealership computer system.
Thanks in advance.
P.S. Any tire recommendations (not Pirelli) for the 18" wheels?
Thanks in advance.
You don't indicate where you are located, so it's going to be hard for someone to recommend a guru/dealership for you to go to.
You might try posting your question on this website and you may get lucky with someone who can answer your questions if there are no answers here:
http://www.ppbb.com/board/986board.htm
Good luck!
Good luck!
Renn,
Thanks for your response. I'm located in the Tampa Bay area. I have a pretty good handle on the mechanics and dealerships in my area, and I trust me mechanic. My questions were about the the faults themselves.
By the way, nice 944 in your avatar (great photo too). My other car is an '89 NA that I've had for almost 14 years. Needless to say I love it.
Well, if you're in Tampa then you need to contact Pedro! I don't think he has much of a presence here on Rennlist, but he is a true Boxster "guru" and hangs out a lot on the Porsche Pete Boxster Board. Here's a link to his website with contact info:
http://www.pedrosgarage.com/Site/About%20Us.html
Thanks for the compliments on the avatar pic - that was taken just one month ago at Virginia International Raceway. Seems like a LONG time ago right now with winter setting in up here!
Thanks for the links; I'll check them out.
If winter gets too long for you, we have the 48 Hours at Sebring in February. If your car isn't set up for racing, there's a DE group as well.
Pedro is the man. His cell is on his website. Super friendly guy. He will help you if he can. He is in Weston, FL. Quite a trip down 75 for you.
I am having trouble with my key, so I took it apart. The back side of the circuit board, where the buttons make the contact that activate the controls, is total cr#p. Mine stopped working properly because the actuators (my made up word, not sure if it is right) on the circuitboard came apart. I put them back together, but it is doing it again, so I have to go in with some super glue this time.
I'll take the key fob apart and inspect the internals. Good thinking on the spare, but I don't have one.
THXBABE, were you at the instructors' school and D.E. event in November at Sebring? Your car looks familiar.
Thanks to all for the responses.
Fractured
Unfortunately I was not at Sebring in November. I have driven Sebring in a 993, but haven't had the Box there yet. The picture in the avatar is at Homestead.
You should ALWAYS have a spare key (that works) and know where it is. Just go to the dealer and have another one cut, buy two remotes and have them programmed.
If you don't have the radio code, they can give you that too.
To get a spare key made involves the dealership sending info etc to PCNA in Atlanta who actually programs the key and will cost you big bucks...just be prepared to bend over...
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
At the local dealership, we (or the Porsche owner) take the car over (it's about 25 miles away) and they supply and cut the key, progamme the remote (s) and make sure it all works while we wait. Nothing to do with PCNA.
Do not know if this process no longer followed or perhaps the process is more streamlined.
Got an S loaner for a few hours though.
Sincerely,
MarcW.
The new remote has a tag with an ID code on it. The tag also says do not loose...
Takes at the most 20 minutes. The key blank is the same as Audi and can be cut on the VAG machine.
