An IMS hypothesis...
Curt went ahead & posted his hypothesis over on our forum where Jake, the guy in the "excellence" article, hangs out some. You guys can go over & read what he had to say about it here:
http://www.boxsterspec.com/index.php?showtopic=1258
He has a wealth of knowledge on these motors.
Nice try but no cigar. Lower RPMs can actually increase bearing load ...
Hi everyone,
So I bought my 02' last August with about 20,000 miles on it, used from a dealer in Upstate SC. The car was 4 years old with the Carfax stating one, maybe two owners... and for the most part it's been reliable though I've had to replace an ignition switch (surprise!), a RMS that healed itself and a couple of window regulators...
I have a hypothesis though.. I bought the car as a fun daily driver and I don't autocross it, or get frisky driving it... I hypothesize that by keeping the RPM's below 4000 to 4500 rpm will prevent IMS failure. It currently has about 33k miles.. I'm wondering if the failure is due to rotational friction and oil starvation rather than metal fatigue and subsequent part failure. I think I saw the car being driven around town by a past female owner so not thinking too much abuse there.. although the dealership bought it from did have some kids that might have beaten it...
What do you all think, lower RPM's = less probability of IMS failure?
Curt
79 928 5sp silver/blk
02 boxster 5sp blk/blk
Curt
The way the car is driven appears to have no bearing (no pun) in the IMS failure's frequency.
My best advice is to just drive the car normally. I would however, advise more frequent oil/filter services (and do not overfill!).
Long ago -- when I bought my '02 - I decided to forego the 15,000 mile oil change intervals in favor of 5000 mile oil change (and filter change) intervals.
That was over 200,000 miles ago... still on orignal IMS. And engine -- after warmed up, sees the whole spectrum of RPMs, though I avoid engine lugging and do not track car. Still the rev limiters comes close to the red line on occasion...
Sincerely,
Macster.
There's another issue to consider. The variable valve timing system operates by adding or relieving tension on the timing chain. Suppose one of the cams were to receive a change in timing before the other, causing a severe imbalance in the load on the IMS. Or suppose the chain guides somehow catch the chain enough while the engine is spinning at a low speed to create a severe load on the bearing.
There's another failure over on 986forum and again, it occured when the car and engine were moving slowly.
Jake, if your reading through...I know you can't reccommend an oil, but can you at least say if you would suggest that a synthetic oil still be used or no and why?
It is not unknown for cam timing selenoids to fail and one bank's ...
Thus based on the above, even if the two cam shaft timing adjustment mechanisms were triggered at different times this doesn't seem to be sufficient to cause IMS bearing failure or even some other mechanical failure centered around bearing but not directly related to the bearing and its function.
Another factor is the IMS only drives one exhaust cam shaft at the IMS bearing end. The other exhaust cam shaft is driven from the opposite end of the IMS.
An arqument could be put forth that at low engine speed -- IIRC around 1400 rpms -- when the timing is advanced that if this adjustment is in the right (or wrong depending upon one's point of view) direction, causing additional load to the IMS by way of the exhaust cam chain, that this could over time wear down, so to speak, the IMS bearing.
I do not know in which direction the tension is when timing advanced at 1400 rpms or allowed back to normal at under 1400 rpms or when the timing is again changed at something over 5000 rpms (word is it is retarded slightly to improve gas mileage) or when rpms drop below 5000 and the timing change is undone.
Given the possibility for frequent cam shaft timing adjustments though and the rather infrequent IMS bearing failure event I don't think the cam shaft timing adjustment has anything to do with IMS bearing failures.
If a cam shaft chain tensioner broke or a guide failed, that could at least initially masquerade as an IMS bearing failure, but my input is any cam chain tensioner/guide failure is an after effect of the IMS bearing failure, not the cause of it.
Sincerely,
Macster.
Unfortunately, it's all speculation on all our parts. The point is that the IMS is part of a much more complicated system than it would appear on the surface and it would take some true, organized failure analysis to understand the cause of the failures.
