Reverse lights
Dear Rennlist Members,
Could anyone please throw any light on this problem?
In about thirty years of motoring, I have never had this happen. The reverse lights (both of 'em) on my Boxster S (year 2000, 3.2, RHD) have failed. I have taken both bulbs out and checked them. They are ok. I have checked the fuse and it's also ok. So I am thinking the following:
1. broken or corroded wire somewhere but where? I have the wiring diagram but it looks quite complicated.
2. faulty microswitch when selecting reverse. However, does anybody know where this is located on a Boxster cause I have looked all over for it. I am thinking that it is located somewhere near the housing for the gear lever but that would apparently mean removing a lot of the centre console to get at it. I have removed some but don't want to remove too much, yet, because it looks like quite a big job, but have not found any microswitch. Does anybody know if the switch is located on the gearbox itself? If so, where? Cause I have had a look and nothing stands out as being an obvious suspect.
3. any other suggestions?
I am at a loss with this one cause it has flummoxed me. Any suggestions would be greatly appreciated. Thanks.
Buz
Buz
Thanks for your help on this. I have found the switch but have yet to do anything about it. Work has been very busy and taken up a lot of time.
Does anybody know whether non-working reverse lights would be an MOT failure? Or would the garage issue an advisory note?
Still... will get the switch changed eventually.
