Boxster & Boxster S (986) Forum 1996-2004
2003 Boxster S engine expired 3.6 conv????
Old 07-19-2008 | 12:39 AM
arenared's Avatar
arenared
Originally Posted by pologuy
Is this a common problem?!
Common on web forums, at least
Old 07-19-2008 | 04:31 PM
pologuy's Avatar
pologuy
So the '97-99 engines had problems, and the '01 and up engines have problems...
2000 the only year without problems?
Old 07-19-2008 | 04:59 PM
blinkwatt's Avatar
blinkwatt
Nope I've heard of 00'-02' 3.2L & 3.4L cracking heads but that isn't anywhere near as common as IMS or linear wall failures.
Old 07-19-2008 | 05:23 PM
pologuy's Avatar
pologuy
Wow...
I mean, this is the kind of thing you would associate with Ford or GM - not Porsche...
Old 07-19-2008 | 09:17 PM
dennisafrompa's Avatar
dennisafrompa
well we live in the age of instant and wordwide communication...and there have been almost 1/2 million of these M96 cars build...so if the problem is only 1 percent that's 5,000 motor issues out there.
There were issues in the Porsche family in the 50s,60s, 70s and 80s...the raw numbers weren't as big and we did not have the www.
As a 66 year old guy who lived in and experienced yesteryear, I assure you Porsche was not perfect.
Drive your car and stop fretting...that's what I do and if it breaks, i'll fix it. By the way NEW crate motors cost less than aircooled rebuilds...and they come complete.
Start chasing problems even in a 356 motor and see how $$$ add up.
Old 07-20-2008 | 01:55 AM
blinkwatt's Avatar
blinkwatt
Listen to Dennis,
I was paranoid as **** when I starting seeing all these IMS failures threads on the forums.....I drive a 01' 986 S with a 3.2L,perfect candidate to explode.
Then I figured,hey if it's gonna blow,I might as well give it a reason to.
I've seen 5 & 6k soo often lately without a hitch I've really developed a lot of trust in the car to where I'm not worried about a IMS failure.
Drive it hard and live like there is no tomorrow!
Old 07-28-2008 | 11:05 PM
VTCMart's Avatar
VTCMart
As much as these horror stories scare my wallet I ain't trading her in for a Corolla just for a bit more peace of mind. Mine regularly sees 6k on the tach and has 86k on her.
Old 07-29-2008 | 01:22 AM
RyanPerrella's Avatar
RyanPerrella
ok, so i want to know, can a 3.6L with vario cam + be put into an 03 or maybe an 01 S?
Will the electronics support such a conversion?
or is the 01 limited to 3.4L conversions?
Old 07-29-2008 | 02:41 AM
JP-"S"'s Avatar
JP-"S"
01 yes but you must change the DME to 7.8 and harness to match.
02 and newer is a bit easier but you still must find a tech that knows his way around the wiring diagram.
Old 07-29-2008 | 12:27 PM
RyanPerrella
Thanks, someone with some information..
Next question, where can i go to get answers on all this stuff? I am thinking of buying a boxster and would probably do a conversion like this at some point in the near future and i want to buy the best platform for this.
The Rennlist boxster forum is a bit...welll just into pictures and what not. Not a ton of technical info here. Where do i go to get all the tech info on these conversions. I would be doing it myself but dont want to reinvent the wheel here and just want to follow the tired and true setup. I realize electronics are a big stumbling block, but mechanically i think i can handle everything.
Do most people run 996 intake manifolds or do they bolt on the boxster manifolds and ancillary stuff onto the 996 long block? I had always wondered this. Its always been said boxster and 996 engines are physically the same, with really only bore's being different. So that would lead me to believe that i could use all the boxster intake and engine mounts and so on and just use the carrera long block.
Any ideas on the above?
Also, Ive only just priced a new from Porsche 3.6L to come to $10,100 which includes the core charge. I dont know if 3.4L's are cheaper, if they are i may go that route, and could also go for a 3.8L or 3.6 x51 or something. Thats all price dependant but i just want to know what engines can be run in this chassis.
Old 07-29-2008 | 03:47 PM
easyC's Avatar
easyC
renntech.org
Old 07-29-2008 | 04:25 PM
RyanPerrella
THANKS ! LOL
Funny, i just discovered renntech.org an hour ago after doing a google search, its great!
THERE IS A TON OF CRAP TO READ NOW!
Old 07-29-2008 | 05:36 PM
gmsracing's Avatar
gmsracing
5-6k on the tach? I run mine to the 7700 limit every chance I get!!!!
Old 08-01-2008 | 04:17 AM
easyC's Avatar
easyC
yeah the non-s car's redline at much less.... and 7700? you enjoy over-reving your engine?
Ryan check out 986forum.com there have been some good answers to your questions over there recently... you can also pm me if you want... Im a week out from having my 3.6 into my 01 986S
Old 08-01-2008 | 05:37 AM
RyanPerrella
pm sent easy
thanks
