slight jolt when accel/deaccel/accel
Hi, I can feel a slightly jolt like engine/tranny/something is moving/has slack if i accelerate and go off pedal and engine is brakeing, same if i then accelerate again, seller mentioned it might be tranny mounts, tried searching around, but a bit unsure what its called on theese models, any pointers to searchwords/threads on the subject would be good.
and is it common that the shifter is a bit "sloppy"? I've driven a lot of 987 boxster and cayman S, and both have none of thise, but hey, this is a 10 year old car, perhaps a bushing to buy, or something to adjust?
Sounds like a bad front motor mount. They are known to fail and cause the issues you describe. The mount is relatively inexpensive and can be a DIY project, depending on your skills.
Here is a link to a site that offers remanufactured motor mounts as well as some good advice regarding the issues you described.
http://www.pedrosgarage.com/Site/Technolab.html
thanks, I have a car lift, air tools and everything, and skills is over average I'd say (hope)
I'll just do it when I pull the engine/tranny for clutch/MRS ++
the remanufactured thing is great, to bad I'm in norway so shipping and handeling kills the deal hehe. new porsche OE mounts are fairly cheap though, a lot cheaper than tranny mounts as well.
kinda just got the car yesterday, so trying to figure out the ins & outs. power is bad, but handeling is very good.
You might have to remove the plastic panel that spans distance across front of engine and covers the front of engine, engine mount, and some accessory drives.
Sincerely,
Macster.
Chris
thanks for the tips on the tranny drop though, thoose things are always good to have when working on new cars I haven't had engine/tranny out on before.
I finally managed get the car-lift in position inside the garage yesterday.. so we are getting closer! spent 3-4 hours to make it move 16 feet. damn thing is 1800lbs. we had a huge truck with crane, and a forklift, still it took forever. was a bit over the top exciting when the brake hit the truck in a slight jolt and let the thing go...
