Boxster & Boxster S (986) Forum 1996-2004
Drag back on power
Old 03-18-2008 | 07:05 AM
sean986's Avatar
sean986
Question Drag back on power
Hi
On driving on motorway in 4th and 5th gear the boxster seems like its being dragged back,like there is a loss of power for a split second.
Also when the car is just idling the revs are erratic dropping to under1 then goin almost to 2!!!!!!!!!!!!!!!
Any ideas would really help. Thanks.
Old 03-18-2008 | 01:34 PM
insite's Avatar
insite
unplug your MAF and go for a drive. if the problem goes away, replace the MAF. FYI, the MAF (mass air flow sensor) is located near the air filter.
Old 03-19-2008 | 08:49 PM
chris_in_nh's Avatar
chris_in_nh
after unplugging the MAF's wiring harness, you will need to reset the DME by disconnecting the neg battery cable for at least 1 minute. then reconnect (the battery, not the MAF) and go for a drive. resetting the DME is essential.
keep in mind that 97-02 cars will need a radio code after the battery disconnect.
if you do need a new MAF, www.AutoHausAZ.com has the best prices these days.
Old 03-21-2008 | 06:03 PM
sean986's Avatar
sean986
Ok thanks guys
ill get it checked and come back to you.
