2003 Boxster 2.7 cam/lifter replacement
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
My wife's 2003 Boxster with 32K miles recently developed a clicking noise on cold start which lasted several minutes per start up. The dealer initially diagnosed two stuck lifters but once opened up also states a cam requires replacement. The car is a Tip and my wife does not overrev the engine. I have owned a number of Porsche's and have never experienced a cam issue. Any thoughts are appreciated.
Thanks,
Mike
Thanks,
Mike
Sorry I'm not gonna be of any help.
I would just like to ask how loud is this ticking noise? Does it vary with engine speed?
This info would come in handy if ever I hear a ticking noise on my car in the future.
Thanks.
Thanks.
I had the same problem with a 2003, they replaced the intake cam and all the lifters. My check engine light came on no noise that I could hear.
It was in the shop for 14 days while they figured out the problem.
Thanks,
Mike
Thanks,
Mike
Everyone worries about the pistons/rings/cylinders wearing out prematurely and they certainly can under the right circumstances, but the camshaft lobe/lifter interface is one harsh environment. The valve spring pushes back with a force of around (roughly) 170 lbs when the valve fully open.
Given the very very thin and only a half inch so or wide cam face that contacts the lifter face this 170 lbs of pressure translates into maybe 170,000 pounds per square inch of pressure there. Every other revolution of the crankshaft, from 350 times per minute at idle to 3600 times a minute at redline, day in, day out, engine cold, warm, or hot, with fresh oil or oil with 15,000 miles on it...
The problem might have been a marginal camshaft lobe hardness treatment. But it might be due to extended oil change intervals.
With modern oil makers cutting back on anti-wear/anti-scuff additives to improve O2 sensor and catalytic converter performance for a longer period of time, many oil lubricated areas of the engine are at increased risk of accelerated wear, not the least of these areas is the camshaft lob valve lifter interfaces.
Sincerely,
Macster.
