Boxster & Boxster S (986) Forum 1996-2004
Hammer or Airbag tester in Northern Virginia
Old 02-12-2008, 12:36 AM
glencase
glencase's Avatar
Default Hammer or Airbag tester in Northern Virginia
Does anyone in Northern Virginia have a Hammer or something else to pull codes from an airbag system on a 99 Boxster.
The airbag light is on solid but the seatbelt light is off, I've seen posts about seatbelt buckles causing the light but I'm not sure if that would mean the seatbelt light would be on as well.
Thanks in advance,
Old 02-12-2008, 11:40 AM
GMS
GMS's Avatar
The Hammer won't work on 996/Boxster vehicles. You need the PST2 or Piwis tester. If the air bag light only is on, more than likely needs the seat belt buckle and wiring connection update.
Old 02-12-2008, 02:06 PM
insite
insite's Avatar
durametric works, too
Quick Reply: Hammer or Airbag tester in Northern Virginia
