Will 19x11 Champion wheels fit a 99-02 Boxster?
I'm thinking about buying a older Boxster as a daily driver. I have a set of Champion Motorsports RG5's laying around.
The fronts are 19x8.5 and the rears are 19x11. The tires are: 235/35-19 front & 275/30-19 rear. I believe the front offset is 53mm and the rears are about 60-64mm. I could be a little off on the measurements, but close.
They fit my NB 993.
Will these fit a Boxster?
They fit my NB 993.
I doubt the rears will fit. I have 285/30-18 on 10.5" Techarts with 47mm offset. I think yours will stick out almost an inch further (between the extra offset and width) and be taller and I don't see that working, IMO. I think the fronts would work.
Good luck
Randy
Good luck
Randy
