Boxster & Boxster S (986) Forum 1996-2004
Radiator leak - experience needed, please
Old 08-14-2007 | 01:22 AM
Bobiam's Avatar
Bobiam
Default Radiator leak - experience needed, please
I purchased this 2001 Boxster several weeks ago (private sale). It has a minor leak of coolant under the driver’s side radiator which I figured to be a loose hose clamp, since an out-of-state mechanic changed a hose 200 miles before I bought it (I have receipt). WRONG! I tightened the lower hose clamps at both ends and the hose was drippy with coolant. Thought I had it, but not so such luck!
I just pulled off the left front wheel and the plastic inner fender to reveal more. There is nothing leaky that is visible from behind the inner fender.
When carefully examining the front of the radiator through the driver’s side grill, a tiny wet trickle runs down the radiator casing from top to bottom. Looking through the vents at the bottom of the flexible bumper skin, the black plastic front edge of the radiator is visible and is all wet.
There is a plastic plug “looking” item at the top front corner of the radiator that is covering the leak area with a 1.5” diameter rubber shroud looking thing. The plug thing is a half inch in diameter and has some visible threads. The end of it is a X shape that appears to need a special tool for turning it. It goes through a minor piece of painted metal framing. I’d say that THIS IS THE CULPRIT.
Does anyone know what it is, and how it might be tightened or replaced. I can reach it with my hand and arm forced through the bumper skin bottom vent hole, so the right tool can reach it without much difficulty.
If I give this thing to a dealer I’ll need a second mortgage to pay for it. I really need good experienced advice on this. I’m hoping that it does not need a radiator, but if necessary, I’ll disassemble the nose and work on it this winter. The leak has little effect on the coolant level over the 5 weeks that I’ve owned it. I assume that I have Porsche specified coolant. It’s green like common antifreeze…..is the original coolant green?
Help please.
Bob
Old 08-14-2007 | 03:09 PM
senna21's Avatar
senna21
Not sure on the Boxster but more than likely the plug is a bleeder plug/valve. On mid-engine cars the front radiators will have bleeder valves to allow you to bleed out any trapped air in the radiator. I'd imagine that you should be able to turn it by hand, that is if you could get your hand in there. More than likely I'd say it's time to pull the front bumper tighten it down or see if it's been cross threaded. It'll also allow you to clean out the radiators of leaves and other debris. Whoever changed the hose up front would have had to have bled out the radiators after topping up the car with coolant. From your description they either did it poorly or wrong.
Old 08-16-2007 | 03:24 AM
Gary Gaukler's Avatar
Gary Gaukler
I replaced my driver side radiator last year. I don't recall seeing this threaded plug you're talking about. Are you sure it's not one of the plastic "fingers" that attach the radiator to the frame through rubber grommets?
Either way, a radiator replacement is an easy DIY. Last year I found the cheapest radiator at 986online, around $250 or so.
Gary
Old 09-20-2007 | 10:54 PM
Bobiam's Avatar
Bobiam
Sorry that I did not get these postings earlier.... First that I heard of a bleeder or fingers. The plug that I can see but barely touch is threaded and appears to go through a grommet and metal framework to secure the radiator. It's is possible that the mechanic bled the thing without properly tightening it. I'l lget that bumper off soon and have a good look. Thanks for good info.
Oddly, it seems to have stopped leaking, but I don't trust it.
Bob
Old 01-01-2008 | 11:08 PM
Bobiam's Avatar
Bobiam
The car is now garaged for the winter and I finally got around to disassembling it. There is a plastic "locator" on the front of the radiator molded into the plastic end cap of the radiator that is attached to a body bracket. Appears that the previous owner somehow pounded the bottom of the plastic bumper (some kind of curb thing without scraping up the underside of the nose much) which shoved the radiator upward and the locator was stressed badly, causing a crack in the radiator end cap. Because of the plastic bushing that the locator goes through, and the horizontal lengthing of the radiator as it heats pushing it tightly against the the bracket, the leakage was minimal as the car got to full operating temp. Also shattered the bottom of the air scoop out of sight from outside the car.
Radiator = $235. Scoop = $105. Time for a coolant change. As a DIY project, it's not too bad. And a good chance to clean out the radiator road debris.
Thanks, Bob
