Popping and Vibration in steering wheel
Good afternoon,
I have a question I have a popping feeling in the steering wheel if I take a 40 degree or more turn. I don't here the pop, just feel it in the steering wheel. Also I am getting vibration, in the steering wheel, noticeable at 40 mph and the most violent at about 75-80 mph.
Does anyone know what this possibly could be? Thank you in advance.
blilley
blilley
Originally Posted by blilley
Good afternoon,
blilley
blilley
your vibration in the steering wheel could be many things. first thing to check is the condition of the tires and air pressures. are the tires properly inflated and holding air at that psi over a week?
are there bubbles in the sidewall or any other damage? if so, replace the damaged tires to see if the problem goes away (you'd want to replace a damaged tire anyway, obviously.)
another very possible cause is that your wheels are not properly balanced. the most likely cause for this is an experienced person doing the initial balance, or maybe you lost a wheel weight while driving. (happens all the time). for your balancing, i would find a shop that has a Hunter 9700 road-force balancing machine for a perfect balance. you can find one near you here: http://www.gsp9700.com/pub/features/how.cfm
another possibility is that one (or more) of your wheels is out-of-round from hitting a pothole, etc.
