brake pad warning
Rest in Peace
brake pad warning
Do you have to use a scan tool to reset the brake pad warning light?
We have replaced all the pads & sensors and light is still on, they have all been checked for continuity and are ok.
It is a 2000 (non S).
No tool is needed - you still have an open circuit somewhere.
Try taking each sensor off and using an alligator clip to jumper the connections on each wheel. If the light stays on then you have a break in the wiring elsewhere.
Rest in Peace
Greg
