Boxster Electrical Problems
Hi all!
I'm a Swedish owner of a Porsche Boxster -97, I just started it up after it's "winter-rest", but only to find out that the alarm-system, central locking and the electrical windows are "dead". Any ideas what to do? The battery did run out completely during the winter, could that have tricked the electrical system? I did try to disconnect the battery for an hour but that did not make any difference. Would really appriciate any help : )
Best Regards
Marcus
Best Regards
Marcus
Any other things (headlights, seat heater, fan, a/c) not working? I had the same problem last week. I figured it out. Try this. 1. start your car. 2. Turn the key left(towards off) less than a quarter of an inch, it will stop (feel resistance) before shutting down. There is a little "slop" the ignition key is not going and making contact when you let go of it after starting. You need to help it go back to stage 2 once you started. (stage 1 your accessories, stage 2 car on, stage 3 is to start). Give it a try and let me know if that fixed everything? You will have to do this everytime you start your car or get it fixed.
Thank's 99firehawk and 98Boxster! I checked all the fuses and they are all ok. Everything else works fine, except for the alarm system, central locking and the electric windows. So I will give the "ignition key-advice" a try and see what happens: )
Best Regards
Marcus
Best Regards
Marcus
You are absolutly correct. The 15 amp fues underneath the seat in the alarm control unit, once blown, will not allow any of those functions to work. Check the fuse it is in between the two connectors it is also a mini and not the same ATC type in the normal fuse panel. Once you replace the fuse check to make sure your alarm functions: I.E. roll the drivers window down activate the alarm and once the system is armed open the door, if the fuse blows immediatly, you more than likely have an alarm horn that has failed and requires replacement. I have run into this on a few cars at my dealer.
