Switch Location- hood light?
I need to keep my hood open over night and do not want to drain the battery. Where is the switch that activates the light under the hood ( front) ?
Roy
Roy
The trunk lights shut off after 2 hours so it will not drain the battery. The switch is in the trunk latch. If you want to shut off the light immediately then take a screw driver and close the latch to trick the car into thinking the trunk is closed. Or, you could pull out the light and disconnect the connector.
