air bag warning light
A new bug has surfaced. The airbag warning light has decided to stay on. My '91 964 had a similar problem. I took it to the dealer a couple of times and had it turned off by the computer (nothing wrong with the airbag), but within days or weeks it would come back on again. I was told by a knowledgable mechanic that this was a common ailment in 964's and the fix usually involved replacing the clock (the airbag light was in the clock), so I never bothered to have it fixed.
Is this a common Boxster problem as well? Any suggestions? The car is under warranty, so I assume I can have it corrected w/o expense.
It is common on the older Boxsters. They had tin plated electrical contacts. In October 1999 Porsche issued a TSB with a retrofit kit for the older cars which included gold plated contacts. As of 9/2/99 Porsche started using gold plated contacts on the assembly line. I have only heard of 2 post 2000 cars that had the light problem - one of those cars had a problem in the main wiring harness and Porsche paid my local dealer like $8,000 to have it replaced. Jeff
Basic Sponsor
Here's the whole story:
<a href="http://www.geocities.com/esklut/Erics996.html" target="_blank">http://www.geocities.com/esklut/Erics996.html</a>
Go there and click the airbag light link for the info. If your dealer can't get it right on two tries, print the page and take it with you.
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
2004 C4S Cabriolet
1999 C2 Cab
