Window Problems
Ok well I have a problem i put a new regulator and a new motor in a still no power to the window driver's side any idea? I mean there is no noise nuttin . Again the passenger window works fine. Are the windows on a different fuse?
are you sure theres no power? there should only be power with the switch depressed.
The other thing you can check is i nthe door jam theres a small cover you take off where the harness goes trhough. ive seen those fill up with water and casue some issues
no window relay? i mean there is really no noise or anything going on yet before he was making noise then it died out. I remember something being talking about the power disturbtor and the linkage.. when i had no power in my car they told me it was a $3 linkage that blew..
