What Sensors Involved?
I have an interesting question. What sensors are working when the car picks up speed?
I have a 2003 Boxster S and have a ABS, PSM and Rear Spoiler problem. Are they all related?
When I press the spoiler switch manually, via fuse box, I got a Spoiler Control Error. I guess the good news is my switch is working. :-)
Then, the ABS and PSM works, up to 50km/h (30MPH). Then it triggers an error and says ABS Error, Bring to workshop and PSM error, Bring to workshop.
Of coz also, at 110km/h, the spoiler refuses to deploy and I get a Spoiler Control Error.
I've read the Boxster workshop manual. They only mention how to disable the spoiler, not how to troubleshoot it.
Any ideas? Does the car try to do a speed check by trying to deploy at 50km/h and when it doesn't, it returns a ABS and PSM error.
Thanks!
Sprint.
Thanks!
Sprint.
bad abs speed sensor is the 1st thing that comes to mind, that may be the wrong term but there's a sensor, on each wheel I think, that the abs system uses to determine wheel spin
abs and psm are essentially the same system (when psm is there)
I don't know what sensor the DME uses to determin when to deploy and retract but it could very well be the same bad sensor
I've only done it once, but if I manually deploy the spoiler and drive with it I get no errors
Unique Title
My first instinct is that this is a bad wheel speed sensor somewhere. A quick on an OBD-II code reader will reveal if this is the case.
You don't mention it, but if you've recently changed your wheels to a different size, you will get error messages if the tire circumferences, front to back, differ by more than 5%.
Sprint.
