Cracked rim: Is it repairable ?
While I was changing my oil, I noticed what appears to be a crack on the inside lip on the rear rim on my boxster. The crack looked like a small hair on the rim, running from the edge of the rim(where the sidewall meets the rim and is almost an inch long. I scraped it with a screw driver to make sure it was not paint or something and I could feel the screwdriver hang on the crack.
I have 18" Sport Classic 2's, which are aluminum. Can aluminum rims be welded (repaired) ? Is it safe or will it throw the wheel off balance ? its the inside lip so it would not be visible while on the car.
I didn't take a picture but I'll probably be pulling the rim later this week to have the tire dismounted for a closer look. Will snap a pic then.
I have no idea how the crack happened, it's not like I was clobbering pot holes.
Tom
Tom
Yes, unless it is a catastrophic failure it can be tig welded , straightened, turned on a lathe, polished, plated or what ever finish you desire. If it is a two or three piece parts can be replaced. Cost is sometimes the decision factor.
Here's a Boxster S rim that broke into 2 pieces at the track recently.
I didn't talk to the owner, so I don't have the full story. However, you can see a small dent on the inside of the rim in the first pic that stressed it enough to break the whole rim in two. The second pic shows the inside of the tire thru the crack/2 halves.
I am guessing the crack is not all the way through because it is not leaking air. As for repair, I plan to pull the rim this weekend for closer inspection and then see if anyone local can repair it. At $850 for a new replacement, I will look for a used one or repiar it !
Tom
Tom
I had to have my replaced at a similar cost about a month ago.
I saw recently that Brumos had Boxster wheel takeoffs for sale. If you have to replace it you might want to give them a call.
BTW, I had my rim repaired at a local shop here in Columbus. (wheelmedic) Since the crack was on the inside edge, they didn't do much for finishing it other than leveling the weld and then a tad of grey paint over the area. I will say that after they balanced it, I was surprised because it took less weights. I can feel no difference in ride, which is good.
Anyways, I am back in business.
Tom
Tom
I've had a similar crack (inside and about an inch or so long) on my Volvo wheel, also didn't leak. I cleaned it up and used J-B Weld on it and it has not shown me any issues since I repaired it 4 years ago. If you will be tracking your Boxster, I would just replace the wheel as the track stresses are much more severe then on a daily driver.
Driving on a track on cast wheels is already a bit sketchy, cracks or not. Also not saying forged wheels are always superior - it depends. There are too many variables in quality and construction methods to make wide sweeping statements.
https://www.wheelenhancement.com/services Is the best Porsche wheel shop I have been to Located close to LAX airport.
