Boxster & Boxster S (986) Forum 1996-2004
Boxster exhaust option
Old 05-08-2007, 06:56 PM
david borla
david borla's Avatar
Attached is a picture of the Borla system. As you can see the mufflers are much smaller which accounts for the vitality of the sound from this system. It is also much lighter than systems with large mufflers.
Old 05-08-2007, 07:38 PM
blinkwatt
blinkwatt's Avatar
@ Borla,
Do you have a dyno chart of the car w/ & w/o the exhaust? How much does it weight?
Old 05-08-2007, 07:45 PM
david borla
Originally Posted by blinkwatt
@ Borla,
Yes thanks. Will have the info for you tomorrow.
Old 05-10-2007, 02:59 PM
david borla
@ Borla,
Weight Comparison: Borla: 16 Lbs. Factory: 37 Lbs
Horsepower/Torque Data: Gains = 6 Horsepower and 5 lb. ft of torque
Old 05-10-2007, 05:04 PM
blinkwatt
blinkwatt's Avatar
The factory weight is based off of which muffler?
Do you have any dyno charts/graphs?
Old 05-10-2007, 06:41 PM
david borla
Factory weight is based off the original exhaust from the car we used for prototyping. I believe it was a 2001 3.2L opposed 6cyl Boxster S.
I will work on posting the dyno graph.
thanks,
db
Old 05-10-2007, 08:39 PM
Carreralicious
Carreralicious's Avatar
Actually, I weighed my OEM exhaust when I replaced it with my Dansk unit, and found the OEM factory muffler (muffler only, and not including u-pipes or clamps) to be 28 pounds. My dansk exhaust was 26 pounds, and my friend's factory PSE sports exhaust was 41 lbs.
Old 05-10-2007, 09:06 PM
blinkwatt
blinkwatt's Avatar
Thanks Borla,it's great to see a company being responsive and knowledgable as you are! Keep up the good work!
Old 05-11-2007, 07:45 AM
JohnVitamvas
JohnVitamvas's Avatar
The weight of my '00 S muffler with u-tubes, clamps, and the top support was 35lbs on the nose.
Old 05-11-2007, 07:32 PM
david borla
Thanks for the kind words!
Quick Reply: Boxster exhaust option
