Boxster S newbie Q's
on a boxster or a 996, 996 tanks are cheaper if they are the sensor in the side style like 120$ + coolant and labor. the bottom sensor style is like 340$ for the tank + labor 2-3 hours and coolant
boxster tanks are 200-250$ + 4-5 hours labor and coolant
Originally Posted by giskard
Is that right that even the 2000 S's can have RMS failures?
How about catastrophic engine failures? (sleeve failing, etc)
Engine failures are a non-issue - especially for the 'S'. There seem to be a couple posters on this board who insist that there is a major problem with 98-99 MY Boxster (base) engines. However, I see no evidence of such issues and I see very strong evidence of abuse with one of those cases.
What year did PSM first appear in the S? About what % of S's had it?
How about the stiffer (030?) suspension package? What % had it?
I can install it, but how much do they go for if I buy used?
Good luck with your decision.
1) The gas pedal doesn't seem amenable to heel-toe downshifting with light braking. Is this something some folks correct with pedal attachments or by bending something a bit?
2) The gas pedal feels like it has a bit of stiction - is this something correctible with a bit of grease in the throttle cable?
4) It had 18" "turbo look" wheels - would 17" factory wheels be lighter?
5) There was a little red lamp flashing beside the temp gauge, though it was only reading a bit more than 180*F. What does this lamp mean?
6) I didn't try to break the rear loose with power - How does the car behave powering out of corners - does it transition smoothly to power oversteer, and is it controllable and behaved?
Super Moderator
Originally Posted by J-RAD
No need to heel and toe in modern cars but I suppose it can be done with practice if someone wanted.
Originally Posted by Marc Gelefsky
What?? are you kidding?? are you sure you understand what heel & toe is??
I like to heel and toe when slowing for corners that I need to downshift for, when driving spiritedly, because it's smoother, and it's fun. It heel and toes better when you are braking hard, but when braking lightly (like driving 6/10ths), the gas pedal is too far from the brake pedal.
Super Moderator
Yes, but I also assume, unless it's overtly stated somewhere and I missed it, that we're not talking about road racing techniques here. The real purpose of the technique is to rev-match to control weight transfer. For your average daily street driving, there really is no need to heel and toe because rev-matching is handled effectively by the synchromesh. Unless a person is driving like an asshat on the public streets, balance and rev-matching are relative non-issues.
Here is an idea for you
Heel and Toe explained, google is your friend and helps you not look stupid
Wow.. I am amazed... you really have no clue. synchromesh does NOT match revs. I guess you do not downshift much...
Video of J-rad not ever downshifting and being otherwise clueless
And BTW, nice links to sites that describe the technique but nothing about how the transmission works. You do understand that's where the synchros are located, right? - google is your friend and helps you not look stupid! What's more is your last link just uses a lot more words to say exactly what I said above: The real purpose of the technique is to rev-match to control weight transfer. Perhaps if you weren't concentrating so hard on that lump of coal that's obviously stuck up your *** (or perhaps that's your head?) you'd have understood that.
The synchromesh matches the engine speed gears to the speed of the road driven gears, thus speeding up, or slowing down as necessary so that when the teeth match up they're moving at the same speed and mesh smoothly. Without them, you'd need to double clutch to shift smoothly. As such, from that standpoint, for day-to-day driving synchros essentially perform the function of "rev-matching". Now, feel free to go ahead and split hairs on that by yourself all day if you want...
Rev-matching (and thus the toe and heel technique) for use on a road course is a different story and has a single purpose. If you don't think the using a heel and toe technique to rev-match up is for the sole purpose of better control weight transfer, then what DO you think it's for?
(actually, I don't give a rat's *** what you think it's purpose is because I'm not really interested in the "discussion" anymore - internet pissing matches tend to bore me. The guy wanted to know if he could do it, it looks like he has his answer. And I'll work on improving my answers to future questions...god forbid we get your panties in a bunch again)
Porsche Nut
Super Moderator
Yeah, I don't downshift much at all... :
But wow, gee, you really put me in my place......heh.. whatever..I shall not bore your further
Originally Posted by Charlie C
Just curious, what track was the video shot at? Looks like a fun track to drive.
http://www.na-motorsports.com/Tracks/MN/Brainerd.html
It's a very fun, very fast track.
