How do you test the DME for problems?
Originally Posted by deliriousga
I pulled the part out (996.606.115.00) and it seems to be the throttle spring. The throttle cable connects to it and when you let off the pedal the spring inside the part pulls the throttle cable back to idle position. When I twist it like the throttle cable would, the spring makes creaking sounds and it does not return smoothly. I'm going to order the part and replace it later this week to see what happens.
Thanks!!![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
Thanks!!
Was it hard pulling out that unit? Did you take any pictures by any chance?
Gary
Originally Posted by Gary Gaukler
Interesting. Before all this happened, had you ever noticed that when you let off the gas very slowly, the throttle action seemed to be somewhat sticky, as if it didn't want to close the throttle smoothly? That's what I can feel on mine, and I am wondering if I should take a look at the under-dash throttle unit...
Gary
Gary
As far as getting the part out, it's a real PITA. It's located about 6" behind the red circle.
OMG - My Boxster just sent me an e-mail message with some **** in it so that I am not distracted by your post of your Boxster in pieces picture...
I would never have the ***** to do that...
Originally Posted by 99firehawk
you can remove it withou pullign the dash i imagien that makes it a lot easier
IF IT DOES TURN OUT TO BE A DME THE DME IS COVERED UNDER WARRENTY FOR 8 YEARS 80K MILES
Much like the DME you mentioned?? Its nice to have a resource like you here
So what is the fix on the problem? Did you ever fix the problem where your Boxster could not go over a certain amount of RPMs? My 2002 Boxster S with around 23k miles limits me to exactly 1800 RPMs and 10-12 mph in 1st gear. If I shift in to higher gears, the increase in speed is minimal. This problem with mine has happened before but went away for a while...now it is back.
Did you fix the problem? Anyone know of a solution for me?
