How much? RMS replacement
I have a 1997 boxster and is out of warranty. I possibly have an RMS issue. So i'm wondering how much you guys (that's also out of warranty) paid to have RMS replaced in your boxster? Thanks!
...probably $500-800, BUT an RMS leak is not a serious issue. Let it leak and when you need a new clutch or have another reason to pull the trans....then do it.
If it is just drips on your garage floor....Fuggetaboutit!!
Book time on the manual is about 9 hours. You will want to replace the clutch while you are in there. Of course it is about a $15 seal, and a couple of updated case bolts, plus the cost of the clutch.
