Code P1602
Code P1602
Could somebody knows the code P1602
Code 108 Factory code Power Supply and what is the solution for it.
Do I need to check something
Thank Gates
Thank Gates
This fault code (1602) does not necessarily mean that a fault exists. This fault code is also stored in the memory when the battery is disconnected or the DME connector is unplugged. In these cases, simply erase the fault memory and then perform a test drive to see if it re-occurs.
Thanks Loren
I also have A P1126 P1124 I check everything around the intake for air lost and I found nothing . I also change the Mass air flow and the check engine is always return after a short time. I have no black smoke coming out of the exhaust. I don't know what to check now,
Thanks Gates
Thanks Gates
Check Engine Light
Boxster 1999
This morning I took out the car for a drive test. After only 1/2 mile the car start too feel strange and almost nothing to the trottle . Car was shaking and the Check engine light start to flash for about 2 minutes and stay on after. I check the code and I was really affraid. I received code 75,78 ,62,65 everything concerning miss fire on cylinder 6 and catalityc convertor. Can I drive the car to a Porsche dealer or can I check something.
Thanks Gates
Thanks Gates
