Best price on MAF sensor?
7th Gear
The CEL just came on in my Boxster, and all signs point to the MAF, slightly sluggish performance, rough starting at times, etc...
I took the MAF out today and cleaned it, but the CEL came back on with the same code, P0102 I think. Looking around the forum, the best prices seem to be here.
http://www.autohausaz.com/search/pro...0Mass%20Sensor
Any other suggestions on where to buy a MAF? My inspection sticker depends on it! ;-)
Be leary of ones you see listed , used unknow condition. If you cleaned it with a strong solvent based cleaner it could be toast. Best to use clearer specifically for that purpose. What does that code translate to? Looked it up, yep thats what it says. I would buy the new on, try it and if it does the trick put the old one back in and use it till it wears out.
