Imagine Auto 2.5L Supercharger is Live!
Originally Posted by bruinbro
So, if I double the output it is only a 50% increase?
Bro
Bro
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
After year and a half of research, development, and testing, we are pleased to announce the first run of kits are on their way to us as we speak. After we get all the components, and put the individual kits together, they will be ready for shipment to the customer! We have had 2 cars on the road for over a year now with these kits, and the only thing they have needed was a few oil changes.
The official release:
LIMITED FIRST RUN! • • • SECURE YOURS TODAY!
TARGETED DELIVERY DATE 3/13/06
The heart of this kit is the Procharger C1 supercharger. This self-contained blower breaks all the boundaries in the supercharged world. More like a belt-driven turbo than a supercharger, this unit operates at very low temperatures while capturing the highest efficiency ratings for a centrifugal blower. All brackets are CNC’d to exact specifications then powder coated and stamped with the new ImagineAuto/Evolution Motorsports alliance branding. Roto-molded piping ensures a factory look and a very durable system. The kit utilizes all factory components by relocating specific pieces in the system. This means no check engine lights! Instead of trying to piggy back additional fuel in the system we add the proper size injectors and carefully flash your ECU as the factory would with the latest GIAC flashloaded program.
Real world results for the 2.5 were completed on our in-house AWD Mustang Dyno. Base line results were 150 RWHP and after the supercharger was installed, increased to 234 RWHP—a 36% gain over stock. Kit includes:
• C1 Procharger Blower
• Custom CNC’d Mounting Brackets
• Custom Relocated Air Pump Bracket
• High Flow Cotton Air Filter
• Bosch Factory Diverter Valve
• Installation instructions
• Roto-Molded Inlet and Pressure Ducts
• All Hardware incl. Idle Pulleys
• Custom Belt
• Oil for Blower
• All individual Coupling Hose and Clamps
• Custom Proprietary GIAC Flashload Software
• AirPump Extension Harness
A qualified installation facility should have no problem following the included installation instructions. Technical assistance available during normal ImagineAuto business hours.
Price? An affordable $6,995.00. Introductory first run offer, free UPS ground shipping to contiguous 48 states. • 913-310-9927 • www.imagineauto.com •
Call and order your kit today before the 1st run is gone.
• Custom Belt
• Oil for Blower
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/dsc01106_86fbab7e7d0b031d931757ab0bcff740f63eb5bc.jpg)
I bet it doesn't, most street intended kits don't. I remember an intro from a book on how to do your own turbo system, talking about how at full throttle, a mild (7psi) turbo would add roughly 50% to the amount of heat produced by the engine, and that on most cars your stock cooling system can keep up for about 30 seconds. It then asked, if you get out on the road and hold full throttle for 30 seconds, how fast will you be going if you have roughly 50% more power than stock? Track is another story, obviously, and I have no idea how much the author's generalities would fare if actually tested, but they sounded reasonable.
I'd be more worried about the lack of an intercooler, but in my younger and more foolish days I put a supercharger on an NSX and it didn't seem to have any trouble without one. Although, that was probably thanks to an aftermarket ecu and a good dyno operator- the same kit originally shipped with a piggyback unit that would occasionally fail and induce detonation bad enough to kill the engine. And again, no track use, so I never tested the limits of the factory cooling system.
Center rad and 996 Coolant pipes are a bolt on upgrade if needed. Center rad requires S or 996 front bumper cover, both of which bolt on. 996 Coolant pipes (also used on later Boxster S) hold almost 1 gallon of additional coolant.
tcora (03-26-2023)
