Boxster & Boxster S (986) Forum 1996-2004
Headlights question
Old 01-30-2006 | 06:14 PM
Devildog2067's Avatar
Devildog2067
Default Headlights question
I have Litronics. The left side low beam is out but the high beams work fine.
Are there two separate bulbs, ie do I have a burned out light bulb? Or does the fact that the high beams work mean that it's more likely to be a connection problem?
I have a 2001 stock Boxster and the Litronics came from the factory.
Old 01-30-2006 | 07:40 PM
Loren's Avatar
Loren
Yes, two bulbs. The low beam is Xenon and the high beam is Halogen. When you turn the high beams on both are used - the Xenon beam is rotated up to add to the Halogen.
