Boxster & Boxster S (986) Forum 1996-2004
Tire Pressure MPSC?
Old 08-24-2005, 03:21 PM
Kimi322
Kimi322's Avatar
Question Tire Pressure MPSC?
Does anyone run MPSC at the track? Looking for correct tire pressures for a boxster?
Old 08-24-2005, 04:17 PM
Ray S
Ironman 140.6
Ray S's Avatar
I do. I have run them at Road America and Blackhawk. I find they work pretty well with the fronts at 34-35 and the rears 37-38 (hot temps).
Good luck!
Old 08-24-2005, 04:41 PM
Bob Rouleau
Still plays with cars.
Bob Rouleau's Avatar
On my GT3 34 hot all around is near optimum. Some like 32F and 34 R. Several of us with GT3's on Cups observe that the window of optimal pressure is quite small on the Cups on our cars. We can feel a difference at 35 hot and the car is slidely at 36 hot. Ray, try a little less pressure in back and let us know if you see an improvement. Note, my pressures are based on a GT3 with 2.5 negative camber. They seem to work for cars with neg 1.5 equally well. Outside that range, things may be different.
Old 08-25-2005, 12:26 AM
Ray S
Ironman 140.6
Ray S's Avatar
I'm going ro Road America in September. I'll try a little less pressure and see how it goes.
Old 08-25-2005, 09:14 AM
Irishdriver
Irishdriver's Avatar
I Have found that my car is best balanced at slaloms if the pressures front and rear are the same. A friend with a boxster S and trick suspension has come to the same conclusion....
Don't know if it is the same for track work.
Old 08-25-2005, 12:36 PM
Ray S
Ironman 140.6
Ray S's Avatar
I would agree that might work ok in an autocross. However, on the track I believe staggered pressures are best (higher in the rear).
Old 08-25-2005, 01:18 PM
ar38070
ar38070's Avatar
For a boxster on 225/40-18 and 265/35-18 Michelin recommends 32-34 front and 36-39 rear hot..
Old 08-25-2005, 05:52 PM
Bob Rouleau
Autocross needs higher cold pressures because you don't heat the tires as much as you would in a half hour session on a track.
Old 08-27-2005, 06:35 PM
Irishdriver
Actually we lower the pressures....I run all four at 2,5 bar (32 - 34 psi).
Others run them at 2 bar (28 psi)
Old 08-27-2005, 09:35 PM
LVDell
LVDell's Avatar
Great info on the MPSC
http://www.tirerack.com/tires/tirete...currentpage=58
Old 08-30-2005, 01:44 AM
schnell987
schnell987's Avatar
LVDell,
Thanks for the link!
Old 08-30-2005, 11:50 AM
LVDell
LVDell's Avatar
Very welcome
Old 08-30-2005, 09:56 PM
Alan Herod
Lifetime Member
Alan Herod's Avatar
I found them to be very good in the 33-35 range and they began to slide all over at 36 (this is on the 2550 pound SC). Although they were very linear on the way into the pressure window, the over pressure was nearly dramatic and they were significantly slower when going out the top of the window.
Quick Reply: Tire Pressure MPSC?
