New top system with rigid window on old 986
Hi, I have a 1997' model and I need to change all the top system. So, it's very expensive and I am wondering if it's possible to adapt a the new system with the rigid window that equiped Boxster since 2003.
Anybody have an idea ?
I know the adaptable system from BAS but the window seems to be smaller.
thanks !
thanks !
Sure.
Buy the 4 bow frame used on the 2003/4 with the glass window top which has a list price of about $6,500. Then buy the oem glass window top which is about $1,900. Your 1997 has a 3 bow frame and you cannot use the oem glass top designed for a 4 bow frame.
That is why no one has done it. Unless you can get the parts at a decent price from a wrecked 2003/04.
I also have a 1997 with the original top and if it needed to be replaced I would have to think long and hard not using BAS.
http://www.renntech.org/forums/index.php?showtopic=4503
You can probabily get the window top system from dismantlers for a much cheaper price. This is going at 2k dollars.
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
It seems the less weight up high on a car, the better. One of the stated advantages of a horizontally opposed engine is the lower center of gravity. People look for non-sunroof 911's for the reduced amount of weight up high in the car, why would you really want a glass rear-window car? I know the "flex glass", um. plastique....marks the car as an older model............but, who cares?
I live in sunny S. Florida and have a 2000 S: well..the back window was looking fairly ratty and finally got a little crack so I took it to an upholsterer to get a new window sewn in. This guy told me how fortunate I was to not have the heat-sealed glass window in my top because when the heat seal dried and came loose the only thing to do was replace the whole top?? I dunno about that but I DO know that I have a freshly clear flex window in the back, and that's oh-so-nice.
That glass window looks a bit smaller... or is it an optical illusion?
Also, since the original window folds in half, how does this one work???
Sean
Sean
