Boxster & Boxster S (986) Forum 1996-2004
slicks on Boxster S
Old 02-23-2005 | 06:29 PM
1surfer's Avatar
1surfer
8th Gear
Default slicks on Boxster S
Hi
Has anyone had any detrimental effects from using racing slicks on the Boxster at the track,eg oil surge problems etc?
regards Mel
Old 02-23-2005 | 08:51 PM
Palting's Avatar
Palting
I know from owning a 996 that the '99-'01 engines on these cars would have oil starvation issues with slicks. Motosports did have a fix-it, with additional oil pick-up and an additional oil channel bored through one of the heads. 2002 and up, this was reportedly permanently fixed for the 996, and I suppose for the 986 as well. Have not heard of any problems with the newer 996's, and I do run with R-compounds at the track with my '02 C4S. I don't run with slicks.
Having said that, I also have run with 986's MY 99-'01 on the track that run on slicks, with tweaked suspensions and alignments but with otherwise stock engines. Fast SOB's on the turns that give my C4S a work-out. Pretty sure they're generating stupendous G's. No reports of oil starvation from these guys.
Once broken-in, I plan to get track wheels and R-compounds for my 987S.
Old 02-23-2005 | 10:20 PM
JeffES's Avatar
JeffES
We ran a 1999 MY Boxster on slicks (not R compounds) and experienced severe oil pressure drops. Never did it again, but I've driven newer Boxsters on track w/R's and everything's been fine.
Palting is spot on about the Motorsport kit. Well worth it, in my experience, for the older cars.
J
Old 02-24-2005 | 05:12 PM
1surfer's Avatar
1surfer
8th Gear
Any other comments would be greatly appreciated by those having positive or negative experiences with slick use.
Regards Mel.
Old 02-25-2005 | 04:28 PM
Steve Wilwerding's Avatar
Steve Wilwerding
JeffES, how do you know you had oil pressure drops? Did you install your own sensor, or was the oil light blinking?
Old 02-27-2005 | 10:55 AM
JeffES's Avatar
JeffES
Steve,
It was a "mule" w/ additional equipment for test purposes.
J
