Air Bag Light
6th Gear
Air Bag Light
Saulations all I have a problem. The Air Bag light just came on. It's a 98 with 32 K on it. Is there any way I can fix it ? The nearest dealer is over 100 miles away.... Will it hurt anything if I keep driveing it ? I'm out of time on any warr. I'm not sure anyone in Panama City Fl. can even work on a Boxster
You need to see a dealer to see what the fault code(s) are. There is a new buckle kit/ground wires with gold plated contacts but you will not know for sure until the codes are checked.
same problem
I have the same problem, I have access to PST 2 and it shows 21 Ignition Circuit, Driver, after i clear it, it will come back in 5 seconds.
thanks for any hepl
thanks for any hepl
