Immobilizer Wiring
Immobilizer Wiring
Hi
I purchased a 986 S project car that has water damage to immobilizer and rotted the electrical connector. Does anyone happen to have wire diagram for immobilizer since I will be splicing a new connector in. All function work, windows, top, locks etc just cranks very slow and no start. Leads me to believe there's an issue with immobilizer wiring. Jumped fuel pump and it works just not getting pump to come on during cranking.
Hi
Hmmm... that's very interesting. Normally, if the car is cranking, then it's not the immobilizer. Something else is going on especially with the slow crank. Do you have a fresh battery? I would also check all the ground points for corrosion, especially since this is a flood car.
Can I bypas my immobilizer that lost coding?
Hello guys I have a 1998 Boxster 986 that had water damage to the mobilizer. I have bought this car as is and know nothing about it. I have changed the oil in the engine and I would like to start it even just to know that it works, how can I bypass immobilizer to even just say that it runs for a few seconds? (Pins from obd?)
thank you
thank you
thank you
thank you
996love (08-21-2024)
Short answer - you can't simply bypass the immobilizer because it works with other modules including the DME to authenticate each start. The best advice if you're getting a no crank situation that's linked to a damage immobilizer, is to send off the DME, keys, and Immobilizer to ECU doctors in Florida for service. That's the cheapest route. Going to the dealer will of course be more than double for the same service, but they'll want to replace and reprogram a new immobilizer unit. Choose your poison.
I believe the immo is the eeprom next to the Toshiba
