Hi everyone, This started when my key remotes stopped working after the car was laid up for some years. I have removed the 93LC66 EEPROM from the unit from my M534 alarm box off my 2001 986 Boxster and examined the hex dump. I have managed to work out some of the codes for the remote transmitters, transponders and key learning code by trial and error, now I have the key leaning code and a copy of PIWIS 3 and an FVDI to fix the keys but am down a rabbit hole trying to get the rest of the ipas codes I need such as Alarm (ACU) learning code (6 digits), DME/ECU programming code (6 digits), Immobiliser code (16 digits) etc
The codes I have found so far are in the attached jpeg below. I have also attached the raw hex dump too. Hope someone can help....
