986/996 Window Regulator - Correct Stop Position?
4th Gear
Before I purchased my 2000 S it got into a bit of an accident with the driver's side door:
Luckily for me all I had to do was swap a paint-matched door over, but the old window regulator was toast. I bought a replacement and installed it, but since then I've had a bit of a window rattle when closing the drivers-side door. Initial inspection shows everything is tight, but the top of the window can flop around a bit. Digging around forums and the service manuals it looks like my window stop (on the bit of the regulator behind the door speaker that attaches to the door shell) is in the wrong position and letting the window retract too far into the door. Makes sense, I'm guessing the regulator I bought was for a 996. From what I've found, I just need to move the stop to the upper position - but here's my question: which of the two upper positions is correct?
From what I've been able to find in photos and videos there are a few different regulators out there. Some only have one stop at the bottom position, some have two, and I haven't seen others with three like mine although it's difficult to discern from photos and videos so that may not be correct.
If it comes to it I can just pull the other door card off and see what that regulator looks like, but hopefully someone can point me in the right direction
4th Gear
FWIW I moved it to the topmost position last night and the window seems to be operating as it should (with no rattle!)
