PCCM+ Install on 2001 Boxster with DSP
Hello,
I have a 2001 Boxster that I just installed PCCM+ in. The car came with the CR-220 radio, Hi-Fi sound system (490), Digital Sound (680) and the remote CD changer factory options. The PCCM+ head unit powers up fine but I don't get any sound from the speakers. The installation instructions are horrible and I had to redo the connections a couple of times. Here's a list of the things I determined while doing the install:
1) The alarm connection to the radio frame only needs to be removed and taped in cars that have PCM1, my car doesn't have it so I left it connected.
2) The ground line they instruct you to add to the amp connector is only needed on cars with PCM1, my car doesn't have it so I left that connection alone.
3) The Sirius/XM tuner connector replaces the blue antenna connector in the stock 3 connector block. I removed the stock blue connector and replaced it with the Sirius/XM tuner connector and the connected Sirius/XM tuner I bought from Amazon.
4) I installed the MOST box on the frame and connected it to the PCCM+ head unit, my car does not have MOST but this shouldn't hurt anything having it connected.
Anyone here install PCCM+ in a similar car and come to different conclusions, have issues getting sound or have any advice?
Thanks in advance!
Thanks in advance!
Add on question-
Regarding #2) The ground line they instruct you to add to the amp connector is only needed on cars with PCM1, my car doesn't have it so I left that connection alone.Where does it say to place the ground? I added Bluetooth to my Boxster and I’m getting a whine that I suspect is a grounding issue.
sorry I’m not any help on your original question
The ground is specific to the factory amplifier, I don't think it would help your issue. I would recommend taking it to a car audio specialist and having them look at it, probably a simple fix.
Received 1,844 Likes
Hello,
Thanks in advance!
Thanks in advance!
I wouldn't worry about installing anything associated with MOST, since that technology wasn't implemented until MY2003.
Thank you, the instructions say the ground line is only needed with M662 (PCM1) and M680 and since I only have M680 I assumed this was not needed but was my next attempt at a fix. Thank you, I will try that today and report back on the results.
ZuffenZeus (07-05-2023)
Thank you so much @ZuffenZeus, that fixed it. Replaced the wire at pin 17 with the ground line, changed from CAN to AMP and did a Factory Reset. Paired my iPhone and now everything works perfectly.
