Ignition out of order on coolant leak!
5th Gear
Dears,
A funny thing occured onto our recently bought 986 - 1998 - M96-20 2.5L engine with 5Speed gearbox.
We have got a cooland leakage in the trunk due to a deffective collar.
Well, a significant amount of cooland drained thru the trunk floor and go into the chassis structure..
Leakage fixed, we have tried to start the car, but ignition refused to work!!
So, we've put the car on the elevator and seen the cooland appeared underneath, coming from chassis structure...
I've removed a rubber part to inflate compressed air into the structure, to dry it.
2-3 minutes later, I've tried to restart and engine started properly!!!
Well, I can't understand why ignition was blocked by this leakage!
No electrical part seemed to be touched by coolant...
Any idea?
Thanks!
Any idea?
Thanks!
Al Allen (07-04-2022)
Une possibilité est que l'électronique pour le contrôle du moteur is monté au fond de la valise, entre la valise et le moteur, sous le tapis, c'est possible que le liquide a monté dans le tapis et causé des problèmes. C'est un peu tiré par les cheveux, mais je ne vois pas d'autre lien entre liquide de refroidissement et un refus de démarrer.
(One possibility is that the engine control electronics are mounted un the carpet in the rear of the trunk. The coolant may have been sucked up through the carpet and caused a problem. Perhaps a bit far fetched, but I don't see any other link between a coolant leak and a refusal to start).
5th Gear
In fact... no!
We've checked wiring loom into the trunk...
This is the first part we have dried, day before.
We have used a borrow scope today to check if any connection is passing trhu this structure; then nothing!!
Anyway, car is now running well; this is the most important point!
