Is this normal temperature while sitting/idling?
Drove the car for the first time since I bought it couple weeks ago. Car ran perfect the whole 30 minute drive with the temp gauge being the slightest bit above 180. I then sat in the inspection line for a couple of minutes (only about 60 degrees here today) and noticed it went up to this. It did not keep creeping but did scare me a bit and was wondering if I should be concerned.
Doesn’t look terrible. Ideally around 185F is where you want to be. Check the fans and replace the coolant cap
The OPs temperature looks standard. That's where mine has been sitting,.. forever.
Waiting...
OP - Your temps are fine and normal.
Fans are coming on when AC is on so I don't think that is the issue. I don't mind replacing the coolant cap but it looks fine so rather not replace if not needed.
It's easy enough to test: simply run the A/C and note the cooling fan speed (both sides), then shut off the A/C and let the car idle until the fans kick in. Should be at a lower speed than when the A/C was on.
The resistor packs are a royal pain in the rear to replace (you'll need to remove the plastic inner fender and the cooling fan). As long as the fans both run on high speed, if one or both of them are bad, it's certainly not a fatal issue.
The A/C will command the cooling fans to run on high, while the cooling system will have the fans run at either low or high speed. At ~206F coolant temp, the fans will kick on at low speed, switching to high at ~216F. If you have blown resistor packs (and they do that), I'd propose that you'll see exactly what you're describing above. FWIW (and it's a data point of one), my 986 temperature does not rise when the car is idling with the engine running - not on an 90F day, certainly not on a 60F day.
It's been a couple years for me... correct me if I'm wrong. I don't want the OP to be discouraged... if it's a simple job.
I replaced both my fans. Remove the wheel... shroud... gravy. I recall the resistor (big fatty) sits at the bottom of the fan. Removal of the fan is unecessary. Clip some wires... wire in the replacement... done.
