98 base front bumper cover
Hi all. New to me 98 Boxster base. I am about to remove the front bumper cover to get rid of the debris collection around the rads and condensers. Before I started I thought I'd check to see if there are any fitment issues or realignment issues for reinstall. Hopefully it is as simple as it appears.
It is as simple as it sounds. When putting it back on watch for the air temp sensor on the passenger side intake and make sure the rubber ducts feeding air to the rads are seated properly in the grooves of the bumper cover. I used a bit of silicon spray lube on the rubber to make it slide in easier.
