Driver Side Window Stuck Down
Drove home from the Studio the other day and put my window down and when i got home my window was stuck permanently down(All the way). When you press the button for it to go up it makes no noise or anything. Need to get a new motor for the window? What do you think the problem could be?
That window switch itself can deteriorate with age. Try to patiently have various soft touch attempts applying pressure in various angles and increments.
I have a switch that I need to remove and get a good look at because it works intermittently and requires finesse to operate it.
