Easy to change headlights?
Ironman 140.6
The fronts are event easier than the rears. Doug if you have the tool (located in the tire spare kit) you will be able to swap them our in less than 15 mins
Wow...thread from the past! Sadly, I'm...er...currently between Boxsters.
Hey guys, Wayne over at Pelican Parts is having a book out (hopefully) by Xmas called "101 Projects For Your Porsche Boxster". Promises to be a good one!
Hi Both,
OK here's a good question: Ive moved from the UK to the Netherlands with my little Boxter 986 2003. The only thing is I went to get a APK (MOT) and they say that the beams on the headlamps are not pointing the right direction (for RHD not LHD) and also my fog light on the rear is on the wrong side.
I really don't want to fork out for 4 lights, it there a way to adjust the headlamps to point in the right direction and can I swap the fog lamp to the other side?
This may be a a hard question, as I've been searching for hours on the net.
Jason
Jason
