Locate: Idle Control Valve 2.7 engine
Hi all,
I'm having idle problems on my 2002, Porsche Boxster when it first starts up, I wanted to check the Idle control valve. Unfortunately, I can't find anything that shows where its located. I have a 2002 Porsche Boxster 2.7l engine.
Any graphics or instructions on how to access it would be awesome!
Hi all,
With idle issues and no error codes/CEL my advice would be to calibration the e-Gas system. This should be detailed in the owners manual. For my 2002 Boxster 2.7l (from memory) with the key off and your foot off the gas pedal turn the ignition to just on. Leave on at least 60 seconds. Turn off the ignition and leave off for at least 10 seconds. The next time the engine is started the calibration is complete.
The factory recommendation is to after the calibration check for an e-Gas system error codes and if any present address those. The e-Gas system has a problem.
The above "should" be done maybe every 5K miles or after the vehicle has had 12V power disconnected.
If the idle issue is present after you'll have to come back and post more details. Miles. Stock or modified? When did the idle issue show up. Detials on the severity of the idle issue, and so on.
