Track trouble on the 2->3 upshift
I have a problem with my 2002 Boxster S (6MT) that I have not been able to find any reference to online from another owner.
At this point I mainly track drive my 2002 Boxster S at DEs, and it has seen many modifications over the years. Over the past couple of years, I have started to experience a problem that only occurs after 15 minutes or so on the track and everything is heated up. After downshifting to second for a slow corner and accelerating out of the corner. the shifter will feel like third gear is "blocked" on the upshift and l have to double clutch, put it back in 2nd and back to 3rd.
This only happens when the car is on the track and only when the car is hot. I have had this car for twelve years and have loved it.
Has anyone had a similar issue and have any advise?
I am leaning towards a transmission rebuild with a replaced 2-3 synchro.
I have a problem with my 2002 Boxster S that I have not been able to find any reference to online from another owner.
At this point I mainly track drive my 2002 Boxster S at DEs, and it has seen many modifications over the years. Over the past couple of years, I have started to experience a problem that only occurs after 15 minutes or so on the track and everything is heated up. After downshifting to second for a slow corner and accelerating out of the corner. the shifter will feel like third gear is "blocked" on the upshift and l have to double clutch, put it back in 2nd and back to third.
Has any one had a similar issue and have any advise?
Probably need to replace engine & transmission mounts. California Motorsports shift arrester helps too. Check out their website.
That was my one of my first thoughts, that the powertrain was shifting under load. The engine mount is 2-3 years old. I replaced the transmission mounts with the Wevo mounts last year to no avail.
Anybody think it is worth trying the Numeric shift cables before I pull the transmission?
I experienced clutch and shifting issue on the street at normal temperatures from brake/clutch fluid that was just 2.5 old.
Thanks for the idea, unfortunately we did bleed the clutch last year with no improvement and I bleed the brakes several times a year so the fluid is fresh.
well, i don't experience quite the same thing, but shifting at the track gets very vague for me when things get hot. like you, most noticeable in the moves between 2 and 3 (such that i once hit 1 on an upshift to 3 ...). got better when i put stiffer transmission mounts in (rennline with street/track rubbers). less noticeable improvement when i put a function first street/track engine mount insert in. i think shift cable getting hot (run over the engine) are part of the issue so thinking cup (numeric) cable should help things but not had the chance to install/test yet.
I suspect there is something amiss with the synchronizer for 3rd gear, or the 3rd/4th operating assembly (synchro hub and sleeve). Which is not surprising given the use you give the car and its age. It is also possible that there's an issue with the shift fork or its rod. Let me know if I can help.
I have new never installed numeric cables I will sell.
Following, I have a similiar problem sometimes on the track, but very intermittent.
I'm experiencing the same thing as the OP on track on my 04 S. Did new shift cables resolve the issue? I have flushed the brake/clutch fluid and installed new engine/transmission mounts. Thanks
