Trying to buy a 986 Boxster S
I am looking to purchase an used 986 or 987 Boxster S. I found a 2001 986 Boxster S with 150,000 miles. He is the original owner.
He told me the car is fine except 2 problems: 1. Every time that he tries to lock the car, the car will unlock itself later. It seems like the computer thinks that one or both doors are not completely closed or something. 2. It couldn't pass California smog since we are in California. I asked him about the ODB error code. He said he will get it from his mechanic later. The ODB code should give us a good clue of the problem, right? Any input / advice about the problems above especially item #1? Thanks :) |
#1: Don't lock the car. Locking a convertible is asking for someone to cut your $700 top to protect a $200 stereo.
#2: I live in PA, I have no idea about smog. However, I don't recall seeing a lot of smog problems with Boxsters, and there are a lot of them on the road. So I expect that whatever it is will be an easy fix. |
With 150,000 miles you may need to replace the converters I have a good pair I will sell if you need that.
The door has a couple switches that notify the computer what position the door handle is in, those switches fail sometimes. not to expensive but not easy to replace. |
Originally Posted by Byprodriver
(Post 15802581)
The door has a couple switches that notify the computer what position the door handle is in, those switches fail sometimes. not to expensive but not easy to replace. 2. For replacing the door switches, how many hours of labor should I estimate from an experienced Porsche mechanic? How sure are we that it is the problem of the door switch? Thanks a lot. :) |
$250 for front or rear pair. Not sure about labor rate for door switch I have not had any problem with mine. Search for people that have posted about it
Originally Posted by doridori
(Post 15802797)
1. Do you mean the catalytic converter? How much are you selling your pair?
Yes, get the exact codes. And remember, he may know things he isn't telling you.
(Post 15802933)
Would the ODB code be able to tell whether I need the front or rear pair? If not, how can I tell whether I need the front or rear pair? What city are you located at? Thanks |
(Post 15805508)
Hi Byprodriver,
Would the ODB code be able to tell whether I need the front or rear pair? If not, how can I tell whether I need the front or rear pair? What city are you located at? Thanks My converters are in FL that's why I don't need them anymore. |
(Post 15801911)
He told me the car is fine except 2 problems: 1. Every time that he tries to lock the car, the car will unlock itself later. It seems like the computer thinks that one or both doors are not completely closed or something. 2. It couldn't pass California smog since we are in California. I asked him about the ODB error code. He said he will get it from his mechanic later. The ODB code should give us a good clue of the problem, right? Any input / advice about the problems above especially item #1? Thanks :) If the car unlocks the doors on its own this can be a bad door lock controller, water in one/both doors, water under the seat which has the security module wet. The door lock controller can be replaced. It is not that expensive. Water in the doors is due to a failed membrane. This can be replaced. They age and leak. I had to replace both in my 2002 after 13 or 14 years. Water in the cabin under the seats can come from several places, the most common is a body water drain has blocked up and overflowed. You need to be very sure what's going on with the doors. In CA the seller is responsible for getting the car smog'd. If the one/both converters are bad that can be bad news. CA law prohibits using "used" converters. You either have to buy factory converters (for my Boxster over $1000/each and this was 4 years ago). Some companies offer EPA/CARB approved replacement converters. The CARB web site (or maybe the EPA website) has a list of manufacturers. |
Originally Posted by Shawn Stanford
(Post 15802502)
