1999 Rear Plastic Window
Hello!
I am Los Angeles based and just bought a 1999 Boxster that needs a rear plastic window replaced. Can anyone recommend a good shop that is reasonably priced in the LA area?
the problem with replacing the rear window is that one has to remove the top when installing the window so you are paying the price of a top replacement, less the cost of the rest of the top. Auto Tops Direct has inexpensive quality tops so the best advice is to buy a new top and replace. Should be 450. and the labor 350.
8224 Greenleaf Ave. (At Whittier Blvd). I have used him for a few upholstery related items, including a replacement window on my 2000 Boxster S. I have had others in the area sew in a new window, but Frank's craftsmanship is the best I have seen. 562-696-2123.
