2006 Boxster S Tiptronic throttle problems
First gear wound up? Fifth at 2000 RPM?
Warm engine? Just started?
When was the last time it ran correctly?
Anything done to it since it ran correctly?
Just out of hibernation? Stored inside? Rodents around? Looked for obvious chew marks?
JUST PURCHASED THE CAR WITH SINGLE OWNER, CLEAR CAR FAX AND LOW AVERAGE MILES. HAPPENS WHEN ENGINE WARM AND USUALLY HAPPENS WHEN I STOP AT A LIGHT OR STOP SIGN AND ATTEMPT TO DRIVE OFF.
INDEPEDENT SHOP LOOKED AT IT WITH A TECH LINKED UP IN THE CAR AND WHEN IT HAPPENED THERE WERE NO FAULT CODES.
